Eric90 Posted May 14, 2024 Report Posted May 14, 2024 Hi I have a server room on the ground floor at the bottom of the stairs (two storey office) means of escape. Currently the door has a two metal grilles with nothing in between (just the hole 150mm x 150mm) no intumescent etc. Is there a cold smoke type of grille on the market? Many thanks in advance. Quote
Rahel Lock Posted May 15, 2024 Report Posted May 15, 2024 Hi Eric you could use our fire rated intumescent air transfer grill which is available in the size of your hole (150x150cm). I hope this helps. Rahel Quote
Eric90 Posted May 15, 2024 Author Report Posted May 15, 2024 3 hours ago, Rahel Lock said: Hi Eric you could use our fire rated intumescent air transfer grill which is available in the size of your hole (150x150cm). I hope this helps. Rahel Hi Rahel, Yes thanks for that I have used your products in the past for this and was looking for something that specifically controls cold smoke? Many thanks Quote
Rahel Lock Posted May 15, 2024 Report Posted May 15, 2024 Hi Eric ok, thanks for pointing this out again. We don't currently have any air transfer grilles that work on cold smoke. Maybe someone else here has any experience? Thanks Rahel Quote
Mike North Posted May 15, 2024 Report Posted May 15, 2024 This would not stop smoke which is what is needed at the bottom of a stairwell Quote
AnthonyB Posted May 15, 2024 Report Posted May 15, 2024 You'd need a combined fire & smoke damper - these are usually powered and linked to a fire detection & alarm system. For example you fit this to the door or doors: https://www.firesealsdirect.co.uk/passive-fire-protection/intumescent-grilles/fire-smoke-air-transfer-grilles/lvn20s/lorient-lvn20s-fire-smoke-resistant-air-transfer-grille-kit-200x200mm-54mm/ Then link them to this control & monitoring system: https://www.firesealsdirect.co.uk/passive-fire-protection/intumescent-grilles/talkback-damper-control-system/ Which in turn is linked to your fire alarm system. All vastly expensive hence rare to see. Quote
Eric90 Posted May 20, 2024 Author Report Posted May 20, 2024 On 15/05/2024 at 22:30, AnthonyB said: You'd need a combined fire & smoke damper - these are usually powered and linked to a fire detection & alarm system. For example you fit this to the door or doors: https://www.firesealsdirect.co.uk/passive-fire-protection/intumescent-grilles/fire-smoke-air-transfer-grilles/lvn20s/lorient-lvn20s-fire-smoke-resistant-air-transfer-grille-kit-200x200mm-54mm/ Then link them to this control & monitoring system: https://www.firesealsdirect.co.uk/passive-fire-protection/intumescent-grilles/talkback-damper-control-system/ Which in turn is linked to your fire alarm system. All vastly expensive hence rare to see. Thanks Anthony, wow think that would be too costly! Will recommend replacing door 🙂 Quote
Eric90 Posted May 20, 2024 Author Report Posted May 20, 2024 On 15/05/2024 at 16:32, Mike North said: This would not stop smoke which is what is needed at the bottom of a stairwell Thanks Mike, 👍 Quote
