david wood Posted April 25, 2024 Report Posted April 25, 2024 Can anyone assist on the following please Did labelling of certified fire doors and hinge appear prior to 2000 I live in 3 storey apartment block and during recent investigation found no markings on either door or hinges identifying fire safety regulations I have been advised that the doors are steel lined, would this be a common fire door construction in the 2000 era Any advise would be gratefully accepted Quote
Neil Ashdown MAFDI Posted April 29, 2024 Report Posted April 29, 2024 Are the doors composite construction flat entrance doors? Quote
AnthonyB Posted April 29, 2024 Report Posted April 29, 2024 On 25/04/2024 at 17:02, david wood said: Can anyone assist on the following please Did labelling of certified fire doors and hinge appear prior to 2000 I live in 3 storey apartment block and during recent investigation found no markings on either door or hinges identifying fire safety regulations I have been advised that the doors are steel lined, would this be a common fire door construction in the 2000 era Any advise would be gratefully accepted It did exist since the 80's - but it wasn't (& still isn't) mandatory to be certified and marked. Quote
david wood Posted April 29, 2024 Author Report Posted April 29, 2024 6 hours ago, Neil Ashdown MAFDI said: Are the doors composite construction flat entrance doors? Yes they are Composite Construction entrance doors Quote
david wood Posted April 29, 2024 Author Report Posted April 29, 2024 24 minutes ago, AnthonyB said: It did exist since the 80's - but it wasn't (& still isn't) mandatory to be certified and marked. OK Thank you Quote
Neil Ashdown MAFDI Posted May 2, 2024 Report Posted May 2, 2024 Some composite flat entrance fire doors from that period had metallic faces with timber stiles and rails and the core filled with foam. In my experience these types of doors do not carry any marks and the hinges (as apart of the door-set) or evidence of certification but they may still be fire doors. If you require confirmation of likely fire performance, you could engage a fire door inspector that has wide experience with composite fire doors. Quote
