jamro Posted March 15, 2024 Report Posted March 15, 2024 I am working for a client transitioning a home to a non-licensable HMO. They want to move back in after a few years. They have a good quality, solid 1935mm high opening/frame/lining. All of the doors I'm looking at are 1981mm with too little lipping to bring the door to height. The client hates all of the doors available from made-to-measure suppliers. I understand that it's possible to re-size FD30 doors using hardwood lipping glued in (and not from the top). What's the best method for this to remain HMO-compliant. Please note that this is a non-licenseable HMO. 1) Cut door to size and glue in hardwood lipping of 6mm + 5mm (for intumescent rebate) thickness 2) Router out 11mm groove in base of the door to try to keep veneer intact and glue in a cut-to-size hardwood lipping Are all FD30 doors solid core? Is this best done with a FD30 blank or can it be done with a finished door? Quote
Neil Ashdown MAFDI Posted March 18, 2024 Report Posted March 18, 2024 Better to change the door frames to suit the new doors. If that's not possible either order custom made fire doors from a competent supplier or if you have the necessary knowledge, skills and experience you could purchase fire door blanks and fabricate the doors yourself in accordance with it's relevant technical manual. Quote
