Guest Hello Anthony, thank you f Posted May 7, 2021 Report Posted May 7, 2021 Hello Anthony Thank you for the reply. That's very helpful. Much appreciated. Kaye Quote
Guest Yvonne Posted September 14, 2021 Report Posted September 14, 2021 Hi The company I work for have a 25m x 10m maintenance shed with a roller shutter at either end and two fire doors on the two longer walls. We have only a small amount of mains power which is just sufficient to run the security alarm on, so we are having a generator for powering sockets etc. The generator will not be running all the time. 1. Do we legally have to have emergency lighting above the fire doors? 2. If so can you recommend an alternative that is purely battery operated? Many thanks Yvonne Quote
Tom Sutton Posted September 21, 2021 Report Posted September 21, 2021 You need a survey to ascertain if you need emergence lighting and the type of E/lighting required, emergency torches may be acceptable. Quote
green-foam Posted September 21, 2021 Report Posted September 21, 2021 On 14/09/2021 at 14:02, Guest Yvonne said: We have only a small amount of mains power which is just sufficient to run the security alarm on, Are you sure? To operate any electric doors, a crane, conveyor belt etc does require a lot of energy several Amps so yes a generator may be required in your case. (It may even need 3 phase) but an average emergency light only uses 11milliAmps 11mA is around 2.6 watts, the lamp in my fridge is 5 watts (Yes, almost twice as much) I would be very surprised if the supply you have can not run a few emergency lights. You may be able to use torches, but I would have to ask, if there was a powercut, how would anyone find a torch?* There is such a thing as a "plug in torch" that you plug into a normal socket, when there is a powercut the torch comes on, but you would need to have conveniently placed sockets installed. "plug in torches" for commercial use cost close to £50 each, 3 hour duration emergency lights cost less than 1/2 of that. *It has been shown that if personnel carried a torch all the time "just in case" after a short while the torches would get lost, flat batteries or just forgotten about. Quote
Guest Frank Posted August 4, 2022 Report Posted August 4, 2022 If the ‘main’ light is switched off on an external emergency exit route of a residential property, and the ‘emergency’ light does not come on, meaning the area is in complete darkness, is this a breach of any regulations? -There are no risk assessments in this area. -The ‘main’ light could’ve been turned on if the visitor looked for it. Quote
Tom Sutton Posted August 17, 2022 Report Posted August 17, 2022 Where is the main switches for the main light located, the emergency lights will only come on if the power supply to the main light fails. Quote
Guest Guest Jim Posted January 17, 2024 Report Posted January 17, 2024 I work in a residential training centre with 13 bedrooms. We have Emergency Lights and Signage on all escape routes from the buildings (1 x 3 bedroom, 1 x 6 bedroom and 1 x 4 bedroom). An electrician who was carrying out PAT testing on the premises recently expressed surprise that we don't have Emergency Lights in the bedrooms and quoted BS5266, "at each exit door intended to be used in an emergency". Do the bedroom doors count as exit doors and does each bedroom therefore require an emergency light? Each bedroom is single occupancy and due to the physical nature of our training all occupants are physically fit adults who would not be classed as vulnerable or having additional needs. Our Fire Risk Assessment has not previously found the need for Emergency Lights in each bedroom and a "spot check" by the local Fire Authority two years ago did not pick up on it. Let me be clear, if they're a legal requirement we will absolutely fit them. At present in the event of a fire or loss of power all corridors and escape routes will be lit by Emergency Lights, just not the bedrooms themselves. Any advice or guidance on this matter would be much appreciated. Thanks. Quote
AnthonyB Posted January 17, 2024 Report Posted January 17, 2024 No, individual bedrooms don't automatically require emergency lighting under standards or guidance, it's bending the terminology in BS5266 to sell more lighting & installation. Quote
Guest Guest Jim Posted January 18, 2024 Report Posted January 18, 2024 Many thanks for the quick response @AnthonyB - that was my understanding but I wanted to check with others more knowledgeable than myself. Quote
Guest Guest Jim Posted January 18, 2024 Report Posted January 18, 2024 One more request please. "individual bedrooms don't automatically require emergency lighting under standards or guidance" - could you point me towards the relevant documents where that appears please? It would be good to be able to quote the relevant part. Many thanks. Quote
AnthonyB Posted January 22, 2024 Report Posted January 22, 2024 BS5266 - it doesn't say you don't need them but doesn't list them as being where you do - similarly with the gov.uk fire safety guides Quote
