Guest Sarah Posted January 15, 2024 Report Posted January 15, 2024 Hi. Advice needed please. New intumescent strips fitted recently are not sticking. Can I use an adhesive? If so can anyone recommend one? Thanks in advance. Quote
Neil Ashdown MAFDI Posted January 15, 2024 Report Posted January 15, 2024 If you use adhesive it will make it difficult to take them out if necessary. Instead you could you short panel pins to hold them in place. Quote
Guest Sarah Posted January 17, 2024 Report Posted January 17, 2024 Thank yo for your reply Neil. Is there a specific brand of pins you would recommend? Quote
Neil Ashdown MAFDI Posted January 18, 2024 Report Posted January 18, 2024 No but assuming the door/frame is timber, stainless steel would be best. Before you go ahead make sure the groove for the seals is clean and consistently of the right depth and width to match the seals. Quote
