Guest paulson Posted December 2, 2023 Report Posted December 2, 2023 I have an emergency light which the green light is only on when it is charging the battery,then goes out, is this correct, i thought the green light was supposed to stay on at all times? Quote
green-foam Posted December 4, 2023 Report Posted December 4, 2023 The green LED on emergency lights does (usually) indicate the battery is being charged and as such should be on at all times, unless there is a power failure. There are a few other possibilities: 1) Some "smart" emergency lights have self testing modes in which case it may be in this mode. (Most will flash the green LED) 2) Incorrectly wired supply 3) EL itself has a problem Make and model of EL would help. As would testing said EL Quote
AnthonyB Posted December 4, 2023 Report Posted December 4, 2023 On 02/12/2023 at 10:56, Guest paulson said: I have an emergency light which the green light is only on when it is charging the battery,then goes out, is this correct, i thought the green light was supposed to stay on at all times? It should only go out when the power is off and it has switched to battery power (with the main light illuminating). Even with self contained self testing fittings at least one of the colour indicator LEDs should be lit or at least flashing. Quote
