Fire safety requirements for flat owner
I recently bought the top floor flat in a Victorian converted property (5 storeys total and 4 flats, a basement flat with its own entrance and three above with a communal entrance and hallway/staircase).
I have renewed our buildings insurance but have been told this is only valid if we are compliant with fire safety regulations for communal areas.
Do I need to hire someone to do a fire safety assessment for our hallway/stairs? I am an owner occupier but the other two flats that share the communal hallway and entrance are rented and have tenants.
You could do it yourself, but the premises fall out of the scope of the small premises guidance and being a conversion of an older building would fall between two very different guidance documents with very different outcomes regarding installed fire protection and fire procedures depending on when, how and to what standard it was converted, so a degree of competence is required to determine which applies.
If a modern conversion following the guidance in Approved Document B this is your guide:
https://www.gov.uk/government/publications/fire-safety-in-purpose-built-blocks-of-flats
If an older conversion or a modern one that departed from Approved Document B due to the constraints of the host building then this is your guide:
https://www.cieh.org/media/1244/guidance-on-fire-safety-provisions-for-certain-types-of-existing-housing.pdf
