Guest Lukasz
Hi All, I am a leaseholder in a purpose build flat (2 ground and 4 1st floor flats) and the freeholder is proposing an expensive set of works based on a RA recommendations. Me and others would like to consult a person with relevant accreditation/competencies who may be able to advise which works are mandatory and which aren't. Could you advise where I should look for a relevant professional or service?
Many thanks for any help you can provide. Best, Lukasz
Guest Lukasz
Thanks Tony! I have forwarded your details to the Leaseholder's Association dealing with this work proposal, who should get in touch.
I should have mentioned that I am based in Cambridge, so talking face-to-face and showing you the Estate is most likely out of the question. Might you have any colleague based in Cambridge area that you may recommend as it would be easier?
Many thanks!
Possibly, but I can still give you some desktop pointers as to whether the requirements seem way off if I get copies of reports. Sometimes a block does require capital expenditure, but it's by no means a given.
