AdamR Posted July 24, 2023 Report Posted July 24, 2023 In a commercial premises, can combustible items be stored under fire exit stairs, providing an alternative escape route is available? Or should flammable objects never be stored under escape stairs? Thanks! Quote
Crusher Posted August 1, 2023 Report Posted August 1, 2023 Combustible storage in escape stairs is to be avoided. Even for accommodation stairs it is best to keep it to the absolute minimum, and limit ignition sources. If the stairwell is the only area for receiving goods in, then it has to be managed carefully, and firmly! Storage of sack barrows and other predominantly non-combustible equipment can be tolerated if there is sufficient space to keep it well out of the pedestrian route. Quote
AnthonyB Posted August 1, 2023 Report Posted August 1, 2023 On 24/07/2023 at 17:33, AdamR said: In a commercial premises, can combustible items be stored under fire exit stairs, providing an alternative escape route is available? Or should flammable objects never be stored under escape stairs? Thanks! If the stair is a protected route then it should be free from obstruction & clear of combustibles (your fire risk assessment and if the building is modern enough the fire strategy will determine this). Non combustible items could be tolerated but require careful management and monitoring as when people see some stuff stored there they tend to assume they can add to it and combustibles can start to creep in! In the old days of the Fire Certificate combustibles in a protected stair would be a breach of the certificate and thus an offence. Quote
Guest FMC999 Posted July 16, 2024 Report Posted July 16, 2024 On 01/08/2023 at 20:57, AnthonyB said: If the stair is a protected route then it should be free from obstruction & clear of combustibles (your fire risk assessment and if the building is modern enough the fire strategy will determine this). Non combustible items could be tolerated but require careful management and monitoring as when people see some stuff stored there they tend to assume they can add to it and combustibles can start to creep in! In the old days of the Fire Certificate combustibles in a protected stair would be a breach of the certificate and thus an offence. if the escape route is being used as an "office" what contravention is in place, trying to provide reason ( Law) why as the cant do what they are doing. Photocopiers, desk, telephone etc place in escape route. Thanks escape route.msg Quote
AnthonyB Posted July 17, 2024 Report Posted July 17, 2024 It depends on the size and layout of the premises as to whether that needs to be a protected route, however it should be avoided in any case. The bit of the legislation covering this is in Article 14 of the Fire Safety Order: Emergency routes and exits 14.—(1) Where necessary in order to safeguard the safety of relevant persons, the responsible person must ensure that routes to emergency exits from premises and the exits themselves are kept clear at all times. Quote
