3 storey Residential Block
Guest KimboWilko
Three storey residential block, 3 apartments each floor. Construction 2008.
There is a loft area with no detection and the rest of the building is covered with mains linked detectors communal areas only.
As this is a three storey building should this have a fire alarm system installed to BS5839
Should this be tested weekly or monthly?
