Ronan Posted May 27, 2023 Report Posted May 27, 2023 Hi, after changing floor from carpet to laminate, there is a 14mm gap from the floor to the bottom of the fire door. What can I use to fix that? Thank you Quote
Rahel Lock Posted May 31, 2023 Report Posted May 31, 2023 Hi Safelincs offers surface mounted drop down seals here which an be used on fire doors with up to 14mm gaps: https://www.safelincs.co.uk/surface-mounted-drop-down-smoke-seal/?q=gap I hope this helps! Rahel Quote
