David N Posted April 17, 2023 Report Posted April 17, 2023 Hello Can anyone confirm the exact situation regarding replacing all Flat Front Doors with FD30s? Is this mandatory? Regards Dave Quote
Mike North Posted April 19, 2023 Report Posted April 19, 2023 It all depends on where the front door is located, you need a fire risk assessment. Quote
AnthonyB Posted April 19, 2023 Report Posted April 19, 2023 On 17/04/2023 at 18:06, David N said: Hello Can anyone confirm the exact situation regarding replacing all Flat Front Doors with FD30s? Is this mandatory? Regards Dave No - it depends on the size and layout of the block. If it is deemed necessary as a result of the FRA that looks at these factors then it would be, but not as routine. Quote
