Paul B Posted March 20, 2023 Report Posted March 20, 2023 Hi I manage a converted house of three stories with a basement. It was converted pre-1991 so may not have adequate compartmentation. Which guide do I use regarding fire precautions, is it the LACORS guide? Currently there is a BS 5839 Part 4 Alarm panel installed with one detector on the top floor and Manual call points on each floor...will this need improving as the LACORS guide recommends: Grade A LD2 in the common areas with a heat detector in each flat and a Grade D LD3 Non interlinked alarm in each flat? Quote
