Guest Harry Posted January 24, 2023 Report Posted January 24, 2023 Can trim timber/mouldings be added to the surface of plain blank fire doors? Quote
Neil Ashdown MAFDI Posted January 26, 2023 Report Posted January 26, 2023 For certainty on this matter, always contact the door leaf / door blank manufacturer for advice. There isn't much in the way of information on-line on this particular subject but this is quite helpful: https://www.falcon-timber.com/downloads/ Typically guidance on applying facings might look something like this: Quote
Mike North Posted January 26, 2023 Report Posted January 26, 2023 Technically adding a decretive moulding to the door should not be a problem. You need the global assessment for the door so that you use the correct moulding in the correct position and adhesive. Quote
