Guest Ian Posted January 7, 2023 Report Posted January 7, 2023 Can anyone recommend a long life battery carbon monoxide detector that doesn't flash every minute or so? Quote
green-foam Posted January 9, 2023 Report Posted January 9, 2023 The idea of a flashing light is to indicate that the device is still working. If the light is troubling you, you could consider moving the detector, so long as it is still in the area it is monitoring. Quote
