Looking for a bit of help if possible from any fire door inspectors. Can you please explain the actions to be taken if the labels or plugs were not present on a fire door on a fire door certified inspection.
Kind regards
Nigel c
  • 5 months later...
Guest Fire Door
The simple answer  if the labels or plugs were not present on a fire door and there is no documentation that can be varied through the manufacturer then its not a fire door .
