Guest Tim Peters Posted October 27, 2022 Report Posted October 27, 2022 We have received a Fire risk assessment for an apartment block that says the building is compliant, however the fire officer has added a set of recommendations, would all of these need to be implemented? An example mentions the service cupboards opening onto the protected area have a breach to a ceiling void and need to be fire stopped. Quote
AnthonyB Posted October 31, 2022 Report Posted October 31, 2022 It depends on who did the report. Whilst many fire safety consultants will clearly show which actions, in their opinion, are considered necessary for compliance with your duties under the order and which are 'value added' optional good practice, others will phrase everything as a recommendation because you, the Responsible Person, decide what to do, not them. This means it's possible, with some reports, to not do something on the basis it's a 'recommendation' yet leave persons at risk from fire and be liable to prosecution. Compartmentation is critical in blocks of flats so it's very rare for an issue with it not to be necessary for compliance. Quote
Micky.D Posted December 6, 2022 Report Posted December 6, 2022 Hi, i have a similar issue... a recent FRA recommended a Fire Alarm be installed in our Block - 4 Storey Conversion / 6 Flats. No idea when it was converted, no secondary means of escape, just a single stairwell. All Flat Front doors open directly onto the stairwell, doors are also mismatched, so no idea who, if anyone has a Fire Door. The system they have recommended is... Grade A, LD2 coverage in the common areas and a heat detector in each flat in the room/lobby opening onto the escape route (interlinked) Grade D, LD3 coverage in each flat (non-interlinked smoke alarm in the room/lobby opening onto the escape route) to protect the sleeping occupants of the flat. Any advice would be appreciated. Thanks. Quote
AnthonyB Posted December 7, 2022 Report Posted December 7, 2022 That sounds correct for a block where it has been determined that a full evacuation strategy is necessary due to other defects in a legacy building. It's often easier and cheaper than bringing up everything else to a minimum acceptable specification Quote
Guest martin nash Posted December 28, 2022 Report Posted December 28, 2022 AnthonyB. Isn’t the service riser cupboard a ‘protected shaft’? So allowing cables etc to pass vertically through the building without fire stopping every floor? Quote
AnthonyB Posted December 28, 2022 Report Posted December 28, 2022 9 hours ago, Guest martin nash said: AnthonyB. Isn’t the service riser cupboard a ‘protected shaft’? So allowing cables etc to pass vertically through the building without fire stopping every floor? Depends on the block, layout, fire resistance of the walls, fire strategy etc. Often service risers are indeed protected shafts with 60 minute walls and either 30 or 60 minute doors and don't need stopping at each floor (& sadly some RP's have spent substantial amounts on stopping after being erroneously advised it was required), sometimes the design is to continue a compartment floor so as to have service cupboards, you do see both approaches. Quote
Lyledunn Posted January 2, 2023 Report Posted January 2, 2023 On 27/10/2022 at 22:32, Guest Tim Peters said: We have received a Fire risk assessment for an apartment block that says the building is compliant, however the fire officer has added a set of recommendations, would all of these need to be implemented? An example mentions the service cupboards opening onto the protected area have a breach to a ceiling void and need to be fire stopped. It would be a tad bit easier if fire risk assessments were just a simple audit for compliance. But they are not, and by their very nature, they are subjective and that inevitably leads to disagreements between the various parties, which in turn, can boil over into acerbic discord. It is not always necessary for a building to be fully compliant, whatever that means, to have a tolerable risk to persons from fire. However, there are some fundamental considerations such as compartmentation, fire stopping, means of escape, means of giving warning that, whilst also subjective, should be close to current expectations of compliance. Where deviations are encountered in these areas, it is my view that the assessor should set out a detailed justification for any proposed course of action or indeed inaction. It is also inevitable that even diligent professionals will miss something obvious. At the end of the day it should be acknowledged that we should all work together, assessor, client, FRS, et al, to arrive at an optimum level of fire safety, even if some individual’s nose ends up severely out of joint. If I were you, I think I would be back on to my assessor and ask him or her to have a chat with the fire officer. If you decide not to follow the fire officers recommendations, you would be well advised to set out a comprehensive justification for not doing so. Quote
Guest Claudine Posted May 21, 2024 Report Posted May 21, 2024 We have just had a dreadful Assessment on our block of purpose-built flats, where we all own the freehold to them and are self-managing. Many sections were marked 'intolerable'. The floors between each floor are wooden only so not fire-proof and the Assessment says we must undertake compartmentation work. We have spent around £200k on the property in the last 10 years on replacement roof and other upgrades which have removed all internal service risers. But I know that compartmentation will cost us well into six figures. Is this mandatory, when all owners are aware of the construction of the building and the risks - and the evacuation procedure is to get out straight away in the event of fire? Quote
AnthonyB Posted May 22, 2024 Report Posted May 22, 2024 On 21/05/2024 at 15:34, Guest Claudine said: We have just had a dreadful Assessment on our block of purpose-built flats, where we all own the freehold to them and are self-managing. Many sections were marked 'intolerable'. The floors between each floor are wooden only so not fire-proof and the Assessment says we must undertake compartmentation work. We have spent around £200k on the property in the last 10 years on replacement roof and other upgrades which have removed all internal service risers. But I know that compartmentation will cost us well into six figures. Is this mandatory, when all owners are aware of the construction of the building and the risks - and the evacuation procedure is to get out straight away in the event of fire? Do you have a suitable site wide fire alarm system to support a full evacuation policy? If so, whilst a last resort it is a feasible alternative to compartmentation upgrades, which in some properties are not possible or feasible. A good FRA will acknowledge this - I've assessed many buildings where it's the only viable solution so the FRA doesn't scream 'intolerable' Quote
