I have been asked to quote to replace existing Dorma floor springs ( which are not fire rated) fitted to double cross corridor FD 30 & 60 Sapele faced polished doors all with vision panels to a College in Birmingham after a regulation visit by a Fire Inspector
He has suggested we fit 3no 100mm fire hinges to the doors
Our problem is the swing doors open both ways and the edges of the doors have been curved in manufacture to allow the doors to swing freely, so we cannot fit standard fire hinges without cutting off the curved edges on the hanging side to both doors.
We could fit a 15mm hardwood strip to the hanging side & fit the required fire hinges. We would also need to alter & adjust the existing door frames & fit door stops which has been overlooked
Would this process affect the fire rating & integrity of the door as we cannot give a manufacturer's certificate?
I have suggested we could replace the original floor springs & fit a TS 550 NV FP door spring
I look forward to any advice
Pete
If the door can be identified and traced back to the manufacturer it will be possible to check with them to see if this modification is permitted.  If the door cannot be identified you could contact a specialist for advice.   www.afdi.org.uk
If there are >59 people expected to use the door in a fire condition, then the door must swing in both directions.
otherwise as long as the global assessment for the door allows it and the person carrying out the modification is competent then yes
