Can I use intumescent paint instead of fire door seals?
Guest JeffNu
I am upgrading my paneled doors to FD30 rating, but have no intumescent seals in the door sides. Can I paint these with the same intumescent paints to achieve a seal there in palce of using intumsecent strips?
Any advice you could offer would be appreciated.
Best,
Jeff
Hi Jeff
Intumescent paint would most likely not do the trick, as the paint would probably not be thick enough to swell sufficiently to fill the gap. And if it would fail you would be entirely on your own taking the responsibility. Also, the paint has no capability to hold fire smoke back. If you need a simple retrofit solution you can use surface mounted fire door seals
Harry
