Guest Steve Posted August 29, 2022 Report Posted August 29, 2022 Hi can you advise if 1 Inch door stops mitigate the risk from excessive gaps at the top and sides of FD30S fire doors ? Quote
Neil ashdown Posted September 7, 2022 Report Posted September 7, 2022 There is no guidance that thicker rebate stops mitigate the effect of excessive door to frame gaps. Where restricted cold smoke spread is a requirement, effective smoke seals will be necessary. Quote
