Front door fitted with door closer when I am disabled
Guest karenmcgar
im a housing assocaition tenent in a ground floor flat and the housing are trying to get me to have a self closer hinge fitted to my front door
im disabled and cannot open doors fitted with these devices as it causes me great pain do i have to have this fitted is it law ??
Assuming the front door does open onto the common areas and the fire risk assessment requires the door to be a 30FD self closing door, to protect your neighbours from a fire in your flat, then the law does require the self closer. However there are possible solutions have you discussed with the association a Wireless Free Swing Door Closer which could be triggered by your domestic fire alarm in your flat?
