Guest TonyWool Posted June 15, 2012 Report Posted June 15, 2012 Could you please tell me if there is a maximum gap size between the fire door and frame after which the intumescent seal will not work. I have been told by a carpenter that this is 3 mm. Thank you Quote
Tom Sutton Posted June 15, 2012 Report Posted June 15, 2012 That is the average gap and is documented in British Standard BS 8214:2008 Code of practice for fire door assemblies. 9.5.2 Clearance gaps Failure of fire-resisting door assemblies under test is very often due to burn-through at the clearance gap between the door leaf edge and the door frame. Doors should be hung to give an equal gap across the head and down both jambs. A typical gap to achieve good fire performance is between 2 mm and 4 mm. NOTE Guidance on operating gaps for timber doorsets is given in BS 4787-1 and BS 5588-112). Quote
Guest RosalindDav Posted June 26, 2012 Report Posted June 26, 2012 I recently attending a fire risk and safety management course and was advised to obtain a gap gauge with a mirror fixing to be able to check fire doors. I have not been able to find such a unit and wondered if you might be able to advise where this course be purchased? Any information would be appreciated. Many thanks. Roz Quote
Safelincs Posted June 26, 2012 Report Posted June 26, 2012 Hi Roz Safelincs provides these fire door gap testers free of charge. Just email service@safelincs.co.uk Harry Quote
Guest THANK YOU :) Posted July 20, 2017 Report Posted July 20, 2017 Thank you. I have today sent in an Email for 3 of your finest door gap testers!!!! Quote
Safelincs Posted July 21, 2017 Report Posted July 21, 2017 Email received and gap gauges sent :-) Quote
AnthonyB Posted July 21, 2017 Report Posted July 21, 2017 They are different to the BWF ones but still look useful and handy! Quote
Guest Martin Posted October 12, 2017 Report Posted October 12, 2017 Is the offer of free gap testers still available Quote
Safelincs Posted October 13, 2017 Report Posted October 13, 2017 Hi Martin, yes it is, just email service@safelincs.co.uk Harry Quote
Guest Sam Posted November 6, 2017 Report Posted November 6, 2017 I've emailed too for some. Will come in extremely useful!! Quote
Guest Nicola Bruford Posted August 12, 2020 Report Posted August 12, 2020 Hi Just come across this I'm looking for 5 Fire Door Gap cards could I order them here Quote
Safelincs Posted August 13, 2020 Report Posted August 13, 2020 Hi Nicola, they can still be requestyed at service@safelincs.co.uk Harry Quote
Guest Gap on lock plate Posted January 6, 2024 Report Posted January 6, 2024 Hello,How do I solve the gap on frame where the lock plate is my fire door has recently failed because there is a gap between intumesant strip and door latch plate measuring 180mm Quote
Neil Ashdown MAFDI Posted January 8, 2024 Report Posted January 8, 2024 Its OK. The intumescent strip & smoke seal may be interrupted at lock and hinge fixing points. If the inspector/assessor disagrees, ask them to provide specific evidence that the seal must be continuous and uninterrupted. Quote
