Does a new partition need a fire door?
Guest ChrisSmi
We are exhibition contractors and are installing a small partition wall in a showroom that will contain a door to link the rooms.
This will create a small room approx 4.5m x 6m this has double fire doors leading into the warehouse from the showroom.
Does the doors we are building need to be a repeat of the other fire doors with a fire exit sign as it will be leading to the fire exit in the next room or can it just be a normal double door with no fire safety features.
Cheers
Hi Chris
Unless there are new risks you are introducing I cannot see the need for an additional fire door. One thing I would be concerned about is if the room behind the new partition has any other escape route and if the alarm system will protect people in that room if a fire breaks out in the newly partitioned section. Is there a fire detector in the room between warehouse and back room?
Harry
