We have an open plan kitchen and lounge on the first floor of our home - but the ceiling is pitched (height approximately 5-6m).
Do we need to have both a smoke and heat alarm fitted in the top of the apex?  Or would a single heat alarm suffice?
  • 1 month later...
I cannot give definative advice without knowing the layout of the premisses I would need a detailed description or preferably a detail sketch. I am asumimg that your house is an upside down design, upstairs is living and the ground floor sleeping. The upstairs should be a heat detector and should be separated from the downstairs by 30 minutes. The downstairs should be smoke detectors.
  • 1 month later...
Thank you Tom - much appreciated.
