Guest David G Posted April 8, 2022 Report Share Posted April 8, 2022 Good morning We have a set of double doors that open from a hall into a corridor. The corridor is at 90 degrees to the hall (you exit the hall turn sharp left). They currently open outwards, which means the left hand door obstructs the corridor. Is it permissible to have one door opening inwards and one open outwards. ? Thanks David Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted April 11, 2022 Report Share Posted April 11, 2022 In my opion I would say NO, as people passing through the doors is an escape situation only one door would open the direction of escape, meaning you have halved the width of escape. Also one door will still block the corridor, the only answer is the set the doors back into the hall the full width of one door. Quote Link to comment Share on other sites More sharing options...
Guest David G Posted April 12, 2022 Report Share Posted April 12, 2022 Hi Tom Thank you for the reply. Quote Link to comment Share on other sites More sharing options...
