Hyperion Posted April 7, 2022 Report Posted April 7, 2022 Is there a more durable solution than drop down seals? The premise I recently inspected has a high transit of users and the seals are becoming damaged easily. Hardwood strips on the communal doors would be a trip hazard I assume. recommendations would be gratefully received. Quote
Tom Sutton Posted April 10, 2022 Report Posted April 10, 2022 If you cannot reduce the theashold gap to 2/4 mm then smoke seals are required, dropdown or otherwise, checkout whats available. Quote
Guest Jeff G Posted May 30, 2022 Report Posted May 30, 2022 On 07/04/2022 at 12:38, Hyperion said: Is there a more durable solution than drop down seals? The premise I recently inspected has a high transit of users and the seals are becoming damaged easily. Hardwood strips on the communal doors would be a trip hazard I assume. recommendations would be gratefully received. Another solution is to include a threshold strip, hardwood or metal. These will need to close the gap to <4mm (FD30s) but has the advantage of being passive and less prone to damage. However, you seriously need to consider trip hazard so it will need to be under 10mm and contrast colour to the flooring,often chamfered too to reduce trip. I use this method on communal doors where uneven flooring is a issue and a drop down seal will not achieve the requirements. Quote
