Guest Billy Posted March 21, 2022 Report Posted March 21, 2022 Hi if a fire door has hinges that are not marked to anything and the screws are No6, is this acceptable? I am aware all new hinges need to be 1935 certifire and screws should be No8 / 32mm, but if the screws are no6 on old unmarked steel hinges, should the screws be replaced for No8 ones ? thanks a lot Quote
Neil ashdown Posted March 23, 2022 Report Posted March 23, 2022 From what you say I would assume that the fire door has no markings or label? If it had/has you could consult the manufacturer's installation instructions or product data sheet for the door leaf and this will provide the specification for hinges. For example, depending on the door core and/or door stiles material, the hinges may need to be No. 10 rather than No.8 and 40mm or 50mm instead of 30mm. So in terms of best practice, check whether the door has timber stiles or is just chipboard with hardwood lipping. A look along the top edge of the door leaf or removal of any mortice lock/latch should reveal which. If the door has timber stiles No. 8 x 30mm should be suitable but if it is solid chipboard throughout use No.10 x 50mm. For the door frame, the screws should not pass through the jamb to the other side and the screw heads should fit correctly in the recesses of the hinge blades. Also check that the middle hinge is central or above in door leaf height. Quote
Guest Billy Posted March 23, 2022 Report Posted March 23, 2022 Thanks for that Neil so IF the current screws are No6 would you replace with No8s (or 10s if chipboard) or because its old doors can the No6s be left, or just recommend that if hinges are replaced / upgraded, to use No8s when replaced ? Quote
Guest Billy Posted March 24, 2022 Report Posted March 24, 2022 hello, reply not seem to have worked, I`ll try again Thanks Neil so seeing as they are old doors with no labels or markings, should the No6 screws be changed for No8 screws, I cant find anywhere where it says No6 screws would be ok or strong enough to hold if the wood charred thank you Bill Quote
Neil ashdown Posted March 31, 2022 Report Posted March 31, 2022 (edited) Personally, I would change them because the installation instructions for modern fire doors requires No.8 x 30 / No. 10 x 40 or 50. Also see section 2.3.9 'Hinges' at http://firecode.org.uk/Code_of_Practice_hardware_for_fire_and_escape_doors.pdf Edited March 31, 2022 by Neil ashdown Additional information Quote
