February 19, 20224 yr comment_24104 Hi guys I'm in need of upgrading my current brk smoke detectors. I believe they are either 600 or 700 series. Which current day model would be compatible? Report
February 21, 20224 yr comment_24168 Are these mains operated smoke alarms with battery back up? Assuming that they are, there is no smoke alarm that is compatible with the bases that your alarms have. (BRK pulled out of the European market.) This means you will have to change the base and the alarm. All new smoke alarms should be interlinked (Check to see if yours were interlinked via a 3 core and earth cable) If they did have a 3 core AND earth cable then you can get any mains interlinked smoke alarm. If on the other hand they are NOT interlinked by cable you can get radio interlinked alarms that have a 10 year battery life and do not require an electrician. Safelincs supply a variety of smoke alarms which you can see if you Click here Report
