Cluster flat configuration
Guest Hyperion
What are your views on producing separate FRA’s for individual cluster flats in the same building?
One FRA for the whole building? Or separate ones for the cluster flats? I have had differing requests from different clients on this. Thanks
As each cluster and other common areas are usually under the control of the same client I do it as one - never had any problems.
If a whole cluster is under different ownership (rather than the leasehold of individual bedrooms which is a common model, all shared space retained by the freeholder) then it would be different.
