scott124 Posted January 17, 2022 Report Posted January 17, 2022 Good morning, I'm currently looking at my fire alarms due to the impending changes in fire safety legislation in Scotland. My house currently has 3 Deta 1111 smoke alarms - which appear to be interlinked (when I press test on them only the smoke alarm being tested goes off, none of the others do - but when the smoke alarm goes off through dodgy cooking all 3 go off) is this right? I understand that the 1111 alarms are now dated - and the 1151 are the newer verson - is it worthwhile upgrading these? My house is around 8 years old and the 1111 alarms have been in since being built. My house doesn't have a heat alarm in the kitchen, so I need to get one - is anyone able to point me in the direction of a heat alarm which will interlink with the above alarms? Many thanks in advance for your help. Quote
green-foam Posted January 23, 2022 Report Posted January 23, 2022 As your current smoke alarms are 8 years old (Life expectancy is 10 years) I would suggest you change all 3 smoke alarms as well as buying a heat alarm (All must be the same brand) Safelincs do supply smoke and heat alarms Click here Quote
